TwinTurbo.NET: Nissan 300ZX forum - Re: OTHER symptoms of failing BMC?
Subject Re: OTHER symptoms of failing BMC?
Posted by yummy18268 on October 02, 2013 at 3:19 AM
  This message has been viewed 292 times.
In Reply To OTHER symptoms of failing BMC? posted by LJZTT on October 01, 2013 at 12:26 PM
Message If you're not leaking from anywhere else it's def your mc. Your 2ndary cup seal in primary piston is leaking, not holding pressure. Brake fluid is leaking past that seal back into the reservoir. A soft pedal with no visual leaks is a telltale sign. Also only non abs z's have diagonal primary and secondary hydraulic brake circuits
